LB9 Timing with Datalogger questions
Old Jan 15, 2005 | 05:43 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
When running the datalogger with a coolant temp of *35 my timing is at *20btdc. but it jumps around *5 degrees steadily. At 1500rpm, 5%TPS and *100 coolant temp my timing maxs at the preset *40btdc. Im pretty sure my chain has some slack in it. But isnt the timing pretty retard for that temp and load? I only run 93octane b/c thats just a pet peeve. Im not recording any knock except at start-up i had 2 knock counts. Are them 2 counts from the starter?
Old Jan 15, 2005 | 10:14 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Timing will jump at idle in order to stabilize idle.
40 degrees of timing sounds like enough to me.
Ignore the knock on startup, it's normal, and is likely from the starter.
Old Jan 15, 2005 | 10:24 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Thanks Man!
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
