Where to find equipment
Does anyone know where I can find the hardware and software needed to connect a laptop to the ALDL. I did a search and couldnt find it.
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
Car: 89 C2500
Engine: ZZ838, MPFI, Whipple, & 7749 ECU
Axle/Gears: 4.10
ummm....wouldn't the info be found here https://www.thirdgen.org/newdesign/tech/promintro.shtml under the Scan Tools and Wide Band Oxygen Sensors section?
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
Read the article in the second link. It's covered near the bottom, and quite well I might add.
It's also been posted about extensively. If your first search turns up nothing, pick some different keywords and search again. You CAN search more than once, you know.
Don't be a smartass or you won't get any help, especially in this forum.
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
As a quick note, while Trax's intro article is very useful and well done, it is ancient in the timescales of interest. Please don't think that WinBin or GMEPro is the end-all be-all.
Breazlan
Sep 25, 2015 11:20 AM
MikkoV
Sep 9, 2015 04:25 PM
