"Manual Trans" byte not checked even on manual bins. What?? 6E w/ Tunerpro
Old Feb 24, 2005 | 08:15 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Hi guys, it's snowing here so I can't take the camaro out of the garage (otherwise it would get wet and therefore dirty!). To keep myself busy I've been reading through the (very incomplete) 6E notated bin and comparing its notes to Tunerpro. One thing I've been noticing is that the notated bin has the 1st "Air flow mode Word" as Manual Trans , at location 14 byte 0. Tunerpro RT shows this Manual Trans checkbox at the same location under the Word 1 list. BUT, whether I open a known factory manual bin (APYP or a 5 sp. manual 305 bin I also have) or auto bins, this Manual Trans box is not checked (and the checkbox does indeed change the value in the hex, I checked this and verified). Why do the manual bins not have the manual byte on? I have been modifying the APYP for my 4 speed Muncie application, and I'm just curious to know what checking this manual box will do. Is the manual logic just built into other features of the factory manual bins, ie timing/ae/pe/throttle follower, etc, so the manual byte isn't needed?
Old Feb 25, 2005 | 07:57 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Note that there are two manual trans flags in $6E. Also note: no one really knows what they're for.
Cornholio7979
Sep 20, 2018 02:31 AM
Mark_ZZ3
May 24, 2018 01:02 PM
GTAman
Sep 21, 2015 09:57 AM
beast94
Aug 20, 2015 06:44 AM
87Formula4bbl
Mar 8, 2005 11:32 AM
