Prom Burning Equipment?
Car: 1989 Pontiac Firebird Formula 350
Okay, to start this off it is really late at night so I don't really want to do a search for this at the moment. I have been searching for other things and I am getting tired and need to head to bed. What I am wanting to know is what equipment is needed to burn your own chips. I was looking into getting one of jet chips or a hypertech chip but most people keep saying to burn your own. Well if anyone can help me into what parts and equipment I need to buy to start burning my own chips, I would greatly appreciate it.
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
Have you read the sticky posts at the top of this forum?
Especially this one:
https://www.thirdgen.org/techbb2/sho...hreadid=216664
You should get an ostrich to be able to modify your ECM and an ALDL cable to read data from it. Both are available here. You will also need CATS or Tunerpro RT and some form of datalogging software.
http://www.moates.net/index.php?cPath=31
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
another opinion
If you need more advice on if to buy a chip, see this link and follow the one from CaptPicardsZ28.
He has felt the pain.
https://www.thirdgen.org/techbb2/sho...35#post2052635
This post might have ended up as a sticky on the top of the boards somewhere, I found it by searching
