TunerPro 4.0 RT & Free NOW AVAILABLE!
Old Apr 27, 2005 | 01:24 PM
  #51
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
Mark,
As I continue to revel in the use of TP 4.0, let me just say that linking the use of the Difference Tool and the current .xdf in use is very cool. I am in the process of converting my 7747 $42 bin to the 8625 $E6. It would be helpful to run simultaneous incidences of TP 4.0 in order to allow transfer of calibration data from one ecu to the other. Right now I guess I'll need to use 2 laptops.
Old Apr 27, 2005 | 01:38 PM
  #52
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
I don't plan to support multiple instances. It would be a huge headache to implement this late in the game.
There's an easier solution to your problem that I can consider implementing: importation/copying of XDF objects across XDFs.
Old Apr 27, 2005 | 03:06 PM
  #53
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Mark,
Do tell. That was actually the first alternative I had in mind but couldn't visualize how that would be done. I thought of the possibility of simultaneously opening multiple bins with 2 different .xdf files. If I could open a param with one and then a corresponding param with the other, that would be the preferred solution. Sort of a "Compare" capability but across different .xdf's.
Old Apr 27, 2005 | 04:09 PM
  #54
Vortex91's Avatar
Car: Camaro RS '91
Engine: 305 TBI
Transmission: Auto w/ TransGo shift kit
Mark,
Thanks for being so kind to share this program with us.
I'm just getting started in this DIY PROM "hobby" and a tool like TP is a wonderful thing to have.
I noticed a few thing though:
-check internet for updates does not work if you are behind a proxy server
-pictures don't show up when using Help
Also would be nice if one could set the default working folder to a different location (just something to put on the wish list) so you don't have to browse to the folder where you keep your files.
Thanks.
D.
Old Apr 27, 2005 | 04:15 PM
  #55
Mangus's Avatar
Transmission: T5WC
Originally posted by Vortex91
Mark,
Thanks.
D.
- Your proxy needs to have the standard FTP ports open (21).
- I just took a look and pictures show up just fine. That's quite strange that you would see this.
- TunerPro retains a "last used directory" for each individual supported file type. You shouldn't have to keep browsing each time you open a file if all your files of a type live in the same directory.
M
Old Apr 27, 2005 | 06:11 PM
  #56
HydraQuest's Avatar
Car: '87 Pontiac Trans AM
Engine: 350 CID STS Turbocharged
Transmission: T56 6-Speed SPEC Stage II
Like it...
Hey Mark,
Been using the TPRT4 to do ALOT of datalogging lately and I must say, it is much more stable than previous versions. I can actually get more than just a couple minutes of data without it locking on me. I did a run of over 20 minutes today and it never had any problems.
Thanks again for your dedication to 'tuning'. I am one happy registered customer.
Old Apr 29, 2005 | 11:31 AM
  #57
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
So besides importing, are there any places we can get the .XDF files from? I checked craigs site as well as the tunerpro site. I have just been impoting them so far.
Old Apr 29, 2005 | 05:25 PM
  #58
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
You could always make them
The format is open so its possible to do it for your application.
(no attitude intended) Just pointing that out.
Old Apr 30, 2005 | 11:30 PM
  #59
JPrevost's Avatar
Car: 91 Red Sled
The importing feature is useful but I found a few things that could improve on it. Like for example; knowing the formula you can easily calulate the decimal places need. Example; RPM = 25 x val . The ecu import will bring everything in fine but display the RPM as 0000.00 . An eye sore.. maybe just a tickle but I don't need those extra decimal points so I change the floating point to 0 decimal places and it's just a hair easier on the eyes. Remember, I do a lot of research so just those unnecessary zero's tick me off on a bad day. I'm still not done with my xdf file for releasing to the public. I was almost all done when I noticed how bloated and useless most of it is 90% of the time and for 90% of the guys looking to tweak things. So I went back and now have 2 files, one for basics, the other is EVERYTHING.
And like Judd said, you can make your own. Most of the ecm/pcm's we deal with most have the hacks avail so it's only a matter of plugging away on the keyboard.
Old May 1, 2005 | 10:52 PM
  #60
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Oddly enough, we 302 ecu (86-89 2.8 MAF) guys seem to have been skipped in that!
Old May 2, 2005 | 07:53 AM
  #61
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
While hand editing the ASD file this weekend with a friend who is well versed in such things, we fixed all the miscalcs in the current 730 $8d version. HAvent tested them all out yet however, going to try and finish that today.
Also, we modified the ads file in tunerpro 4.0 RT and wasted our time :-) It would not save what changes we made to the file, but it would take a save new parameters that we had added in.(ie we added new things for aldl and they were accepted. what we fixed that was present would nt save) Hence the reasoning for the hand editing in notepad/wordpad.
Is there a base or explanation of the code oyu used for tunerpro? Was habing issue with decimal point place when editing the text and some toher questions, like keywords and such? My first experience doing this stuff and trying to make t as accurate as possible.
Due to some added parameters for logging, is there any way possible to have tunerpro run calculations from 2 diff aldl parameters and calculate me out an average for them live?
thanks
Jeremy
Old May 2, 2005 | 12:40 PM
  #62
Mangus's Avatar
Transmission: T5WC
No, I will not give information on the ADS file text parameters. Instead, I'll fix the bugs you found in the editor.
Can you please give more information on the editor problems? Using the latest available build, I had no problems changing existing items in the definition and saving the changes. Reopening the editor proves the changes were saved.
Please make sure you're using the latest version.
No, no way to run averages of multiple ALDL items. Sorry! Its unlikely that I'll get as fancy with the ALDL output math as I did with the XDF, since the ALDL math needs to be done quickly in extreme cases (11hz update [or more for some hardware] multiplied by many items).
Old May 2, 2005 | 03:32 PM
  #63
3.8TransAM's Avatar
Basically, if we added a parameter to the ads file using the edit function we were able to save it. If we changed an existing parameter to correct the calculations, we were unable to save it and it would revert to its former values.
I will check my version later and report back on it as well as download the latest.
thanks
Jeremy
PS sorry for the typing in above post, morning was rough on me
Old May 11, 2005 | 03:02 AM
  #64
BobbyK's Avatar
Car: 71 BLAZER
Engine: SBC 350
Transmission: TCI 700R4
Axle/Gears: 12 bolt with 3:73's
Mangus,Promintor support...where is it?
I've looked through the help menue and did a search as well but nothing resulted.
Sorry for the newb question.
Old May 11, 2005 | 11:07 AM
  #65
Mangus's Avatar
Transmission: T5WC
Hook up your Prominator and initialize the hardware. There it is.
Old May 11, 2005 | 02:26 PM
  #66
BobbyK's Avatar
Car: 71 BLAZER
Engine: SBC 350
yup,I got it.
Old May 15, 2005 | 12:07 PM
  #67
hot68's Avatar
Car: 68
Engine: 383
Transmission: homebuilt 4l60
Mark,
Thanks.
D.
No help pictures for me either..any ideas?
Old Oct 10, 2005 | 10:38 PM
  #68
koll's Avatar
Car: 1991 Pontiac T/A Vert
I know im a little late (like 5 months late) But I would just like to thank Matt and his program. I consider myself somewhat advanced with comptuers and learning to tune was abit overwhelming. His program helped a lot.
Old Oct 10, 2005 | 10:40 PM
  #69
Mangus's Avatar
Transmission: T5WC
Much appreciated!
Matt
8~)
Old Oct 10, 2005 | 10:41 PM
  #70
koll's Avatar
Mark
Its late and I dropped a BBC head on my foot earlier. leave me alone.
Old Oct 10, 2005 | 10:42 PM
  #71
Mangus's Avatar
Transmission: T5WC
Mark
My wife doesn't see me often enough to remember my name either. Call me what you like.
  #72
koll's Avatar
Ok........................sally
Old Oct 11, 2005 | 02:00 PM
  #73
scorp508's Avatar
Car: Corvettes
Engine: Modified L98 & LT5
Transmission: DN 4+3 & ZF6
Axle/Gears: 3.07 & 4.10
Please forgive the silly question, but what cable is needed to do ALDL monitoring at the same time? I have an AKM cable and an Ostrich en'route to me right now. Are the two of those sufficient to do emulating/monitoring at the same time with this?
Old Jun 13, 2012 | 10:36 PM
  #74
91z28blue's Avatar
Car: 1991 z28
Engine: 5.7l TPI
Re: TunerPro 4.0 RT & Free NOW AVAILABLE!
can anyone help me out i just put a small cam in my 1991 l89 tip... and i am looking for the XFD file to go with my ecm 01227730 or is there something else i am missing?
Old Jun 13, 2012 | 10:38 PM
  #75
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
http://www.tunerpro.net/downloadBinDefs.htm
Mark_ZZ3
May 24, 2018 01:02 PM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
ULTM8Z
Oct 2, 2015 01:25 PM
TexasFormula
Sep 30, 2015 06:36 PM
