Map Sensor Formulas
Old Apr 19, 2005 | 10:37 AM
skwayb's Avatar
Car: 93 GMC Typhoon
Engine: 4.3L V6 Turbo Charged
Transmission: 4L80e
Map Sensor Formulas
Do these formulas look correct for taking the MAP Volts and converting them to kPa? These formulas are from the last couple of pages from the Datamaster Manual.
1 Bar Map
kPa = (0.369 * N) + 10.354
2 Bar Map
kPa = (.0781 * N) + 8 (gives worst case error at Room Temp of +1.27 kPa)
3 Bar Map
kPa = (1.23 * N) + 2.2 (Max error of -.85 kPa)
There are also some data tables in the manual showing your the results using these formulas and what was actually measured.
Manual
http://www.ttspowersystems.com/softw...cs/dm32man.pdf
Old Jan 10, 2008 | 09:05 AM
neoblood's Avatar
Re: Map Sensor Formulas
Are these correct? I mean could I use them to edit my xdf and ads file for a code mask made for a 1 BAR Map sensor?
Old Jan 13, 2008 | 10:24 AM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
I don't know first hand, but given that N is an A/D converter number from 0 to 255 representing 0 to 5V they'd seem sensible, exept that the .0781 multiplicator in the 2 Bar formula need to be 0.781 to make sense. If the 1 Bar formula & numbers here is similar to the one you want to modify then the 2 & 3 bar multiplicators here being approx 2 & 3 times as high as the 1 Bar should at least bring you in the ballpark.
FormulasOnly
Sep 10, 2015 09:07 PM
90formulaVortec
Sep 8, 2015 12:42 AM
Ironhead38
Sep 7, 2015 02:26 PM
Eric-86sc
Sep 7, 2015 02:10 PM
willyjoejr
Sep 3, 2015 09:26 AM
