1226870 help
Old Apr 19, 2005 | 10:09 PM
abustiffy's Avatar
was 1226870 help now general issues
Im using tunercat on an 85 corvette. The car has 30lb/hr injectors, mild cam(not positive on specs atm), and ported intake. Is there an injector constant in the code or should I make the changes elseware? I have tried the display fuel flow rate constant to find NO changes in afr. Any help for this and other advice would be greatly appreciated.
Update.
I changed the injector pulsewidths and got the air fuel a lot closer to where it should be(~14:1 idle) via wideband the issue is the car generally runs bad. I checked timing and compression, everything appears within spec. the compression causes a bit of concern though. ranging from 155 to 145. This is supposedly a fairly fresh motor. The car also backfires. even at idle or no load reving it will pop. before the tune the car would idle in the 12:1 range but the plugs still didnt really look bad, they actually indicated a fairly good runnign motor. Now they are about the sale but 2 of them are a little more black than the rest. The only modifications I have made to the tune are IPW and idle speed. Im pulling my hair out on this one.
Old Apr 21, 2005 | 04:13 PM
abustiffy's Avatar
bump
Old Apr 21, 2005 | 04:18 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Might want to look at upgrading the ecm to the newer 165 as you have a lot more support and $32b and $6E to choose from.
I know they have an inj constant and scalar tables and have been thouroughly dissected via hac, etc.
Don't know what else to tell u as I am wholey unfamiliar with the factory 85 MAF ecm/code.
later
Jeremy
Old Apr 21, 2005 | 04:32 PM
abustiffy's Avatar
I really dont think it is an issue with the ecu at this point. After new plugs, Im putting 24# injectors back in and trying it. I would just like to figure it out before going through the headache of changing the injectors if I dont have to.
jayk2k3
May 9, 2008 05:54 AM
ZaphodB
Aug 11, 2002 01:52 PM
Christos
Mar 24, 2002 07:02 PM
