VEmaster Source Code Released Under GPL!
Old Jun 2, 2005 | 07:40 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
I emailed Joe Georger, the maker of VE Master and asked if he would be willing to release the code. He is a very nice and helpful guy and released the code under General Public License. I tried posting the code on Moates site but it gave me an error "file to large", it's only 2.1 megs. Joe should be posting the code on his website sometime soon but until then you can email Joe (email address on his website) or myself and I can forward it to you.
I am working towards for a minor in computer science but do not have enough C++ under my belt to fully understand the code but until them I'm sure someone else would like to work on it.
Here are some features that would be great to add:
- Add a second dialog box so you can save to a different output file name, instead of over righting the input binary file (very easy to do)
- Feature to select how aggressive it is at adjusting the VE tables. For example when I used this software on my friends heavily modified 350 it took a long time to get the BLM's to 128 since the tune was so far off.
EDIT: The source can now be found here from http://gearhead-efi.com/gearhead-efi...ous%20Uploads/ under file name vemaster2_source.zip
Old Jun 2, 2005 | 08:32 PM
AlexJH's Avatar
Engine: 5.7L V8
Sweet! Can you send it to me? harford@gmail.com
What about posting it on SourceForge?
Old Jun 2, 2005 | 10:48 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
you have mail......
Old Jun 2, 2005 | 11:28 PM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
I'd be glad to host it. Sorry if the upload warnings kicked up. Just let me know offline, and I'll do what I need to and make it available...
Old Jun 13, 2005 | 10:17 AM
AlexJH's Avatar
Engine: 5.7L V8
Bump... is it available on Craigs site? Gmail doesn't let me receive the file.
Old Jun 13, 2005 | 10:41 AM
vernw's Avatar
Don't know what the problem is, but I requested this source right after this post and still haven't received it. I suspect they're really busy on something else for now, so just be patient and I'm sure they'll get back to us...
Old Jun 13, 2005 | 09:10 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Yup, Craig put the file up today under Miscellaneous Uploads.
Thanks Craig for posting the file
Old Jun 13, 2005 | 09:29 PM
vernw's Avatar
Yep! Just found it - thanks to all!!!!
Old Oct 4, 2011 | 01:28 PM
caffeine's Avatar
Car: 89 Firebird Formula
Engine: 3500T
Axle/Gears: 9 bolt/4.11
Re: VEmaster Source Code Released Under GPL!
Is this source code still available anywhere?
Old Oct 4, 2011 | 02:59 PM
EagleMark's Avatar
Thought I saw it still on Moates website in the files. read above.
Old Oct 4, 2011 | 05:31 PM
caffeine's Avatar
Engine: 3500T
The link doesn't work for me and I can't find it on the website.
Old Oct 5, 2011 | 02:32 AM
mistaben's Avatar
Car: 91 corvette
Engine: 383SR
can you use VE master with tunerpro or is it just with datamaster?
Old Oct 5, 2011 | 02:36 AM
caffeine's Avatar
Engine: 3500T
It doesn't really have anything to do with tunerpro. You can use it with logs created from freescan, and you could see what modifications it has made with tunerpro. You could also use logs created with datamaster and check the modifications vemaster makes with tunerpro as well. Using logs from datamaster and freescan should in theory yield the same results.
Old Oct 5, 2011 | 02:37 AM
caffeine's Avatar
Engine: 3500T
Personally I have had good results running my LT1 in speed density mode using VEMaster to help tune using logs created with freescan.
Old Oct 5, 2011 | 02:39 AM
mistaben's Avatar
Car: 91 corvette
Engine: 383SR
... freescan is a software program or part of VE master? - do you have a link from where I can download this by chance? and thanks btw.
Old Oct 5, 2011 | 02:53 AM
EagleMark's Avatar
http://www.andywhittaker.com/en-gb/ecu/freescan.aspx
Although the 20 free trial scans in Datmaster are better.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:14 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
carid
Sponsored Vendors
Sep 10, 2015 09:33 AM
