Knock counts only when cold?
Old Jun 28, 2005 | 08:55 AM
conv90's Avatar
Car: superrammed V
Engine: 396 SBC Speed Density
Axle/Gears: Dana44 3.45
This strange thing happens always:
I like to start datalog from the initial start.
I noticed that when the car is NOT in fully warmed situation I have so many knocks counts and timing removed. every shift of the automtic transmission even if a really small amount of gas pedal is applied, I have 3 or 4 knocks with 2 to 7 deg timing removed!
If the car goes in Closed loop (but NOT completely warmed) I CONTINUE to have knock counts .
Progressively the knock counts strats to be less until the car reaches the full warmed situation..
After this, I have NOT knock counts even if I try adding load at lower rpm. Yes, sometimes I have some knock count, but nothing of particular dangerous (only some fraction of degrees removed).
Coud someone explain me this?
Is it normal ? and why?
-Beppe-
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
efiguy
Sep 27, 2015 01:30 PM
mfp189
Sep 27, 2015 09:25 AM
