Any updates on the LC1 sensor from Innovative?
Old Jul 12, 2005 | 07:51 AM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
Just checking if we have a 730 bin that reads in the LC1 sensor yet? Would be great to have the WBO2 read out with the rest of the data log!!!
Old Jul 12, 2005 | 08:20 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
ummmmmmmmm
You liked running with a wideband on sat huh? :-)
lol
Believe the LC-1 uses the same sensor and as the LM1.
So the patch is already done with the exception of possibly having to change the AFR to voltage curve. that has already been posted here too.
So should be an easy way to go for you.
I "believe" that entire thread(s) is in the sticky, not wholly postive though
later
Jeremy
Old Jul 12, 2005 | 09:02 AM
Car: 1989 Iroc-Z
Engine: 350ci SBC
Yea the WBO2 really makes things easier. I would really like a way to have the WBO2 output with the datalog software. I am unsure on how to mod the tables however to have the correct readings. Also I was wondering if anyone has already done this if they could write up a few words on how to bring the signal into the ECM etc...
Thanks!!
Old Jul 12, 2005 | 03:50 PM
3.8TransAM's Avatar
https://www.thirdgen.org/techbb2/sho...threadid=92543
*holds len's hand*
Hope this one will help u out.
U have Datamaster, now u need the wideband :-)
later
Jeremy
PS I'm j/k
Old Jul 12, 2005 | 05:29 PM
Car: 1989 Iroc-Z
Engine: 350ci SBC
"fingers Jeremy's palm"
Thanks!!
Old Jul 12, 2005 | 05:35 PM
Car: 1989 Iroc-Z
Engine: 350ci SBC
ok I think that hack is for the DIY WB...the thread is a bit dated and the LC-1 just came out. I think the the LC1 has a different output curve?? How do I mod it for the LC1?
Old Jul 12, 2005 | 05:57 PM
3.8TransAM's Avatar
*runs like all @#$% from slow89* lol
Do some poking around on the search function. Have to change the output curve from the DIY wideband to the output curve of the lm1 sensor.
I know I saw it on this board before , but a quickie search didnt find anything. Try using voltage vs AFR or output curves to search as well as Innovate and LM-1
later
Jeremy
Old Jul 12, 2005 | 06:23 PM
3.8TransAM's Avatar
Here ya go "pretty boy" lol
https://www.thirdgen.org/techbb2/sho...0&pagenumber=1
Should find the appropriate output curves and the whole linear and non linear wideband output curves.
I was always lazy and left the LM-1 head in the car and used it that way, will have to figure it out now that my DIY boards are working
later
Jeremy
Old Jul 12, 2005 | 09:49 PM
Car: 1989 Iroc-Z
Engine: 350ci SBC
ok well I looked through all that shi..stuff and I am still pretty lost...anyone have a aujp bin setup for the LC-1??
Old Jul 13, 2005 | 02:11 AM
Z69's Avatar
Z69
Yes, it's been bench tested fine and ran on an AUJP and AXYC bin.
Both of their bins had other issues so it wasn't a clear cut zero errors found test.
I've been too busy to finish up moding the patch to work with AXCN, AXCR, and AXXD?. I want to post the whole set of bins at once.
If your willing I can send you an S19 per the author of the original code. He asked me to not release the code. Or I can patch a bin you send me. Or you can wait for me too have time to finish up my testing. AUJP was the first bin I did so I doubt there is a problem.
Here is where the code came from.
CL WB code
Old Jul 13, 2005 | 07:53 AM
Car: 1989 Iroc-Z
Engine: 350ci SBC
Just read you message about the AUJP LC-1 support bin. Just to make sure.....your code wont affect the NB O2 will it. I am just wanting to run the WBO2 as a tuning aid not as a replacemnet for the NBO2. I would judt like the WBO2 readings to be output in the data stream like in datamaster so then I can see the exact load and rpm along with the AFR the engine is experiencing. So then I can manually go into the tables and make changes. Am I correct that your patch will do this or will it replace the NBO2???
Old Jul 13, 2005 | 08:14 PM
Z69's Avatar
Z69
NB code is intact.
My patch just adds multisensor support to 8D for aldl use.
I haven't had time to do any work on CL WB control.
db057
Jan 10, 2020 08:55 PM
bbsr72
Apr 2, 2016 09:12 AM
aharvel50
Sep 21, 2015 07:31 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
Night rider327
Sep 16, 2015 02:20 AM
