vette bin spark table
Car: 92 Camaro RS
Axle/Gears: 3.73 Truetrac
Can someone post the spark table on a stock vette bin, say ARAP. Not begging for the prom, just want to see the table, I dont have the .tdf file to open the ARAP.bin, so just the table would do. I would like to see how it looks.
The ANHT hac will have a vette table and is SD.
The ARAP is a MAF bin and won't be an easy compare to a SD
type TBI app. like you have since it bases one axis on a load calc or LV8 or something. For 8D, the aujp hac has the most complete comments.
You can go to the stickies to find the hacs or Moates.net has them.
The hac will have what you want and more. You could compare the two hacs in notepad.
Here is just one row of ARAP from the hac
edit: I decided to delete my smart a comment on not searching.....
Code:
; MAIN SPARK ADV vs LD vs RPM ; ; ; 12 x 12 ; ; TBL = SPK * (256/90) ; LC02D: .db 0x00 ; Min RPM Val .db 0x20 ; Min LD VALUE Value .db 0x0C ; COL'S/ROW ;______________________________________________ ; 400 RPM ;SPK ADV LD VAL ;______________________________________________ .db 0x39 ; 20.0 32.0 .db 0x39 ; 20.0 48.0 .db 0x39 ; 20.0 64.0 .db 0x39 ; 20.0 80.0 .db 0x39 ; 20.0 96.0 .db 0x39 ; 20.0 112.0 .db 0x39 ; 20.0 128.0 .db 0x2B ; 15.1 144.0 .db 0x1C ; 9.8 160.0 .db 0x1C ; 9.8 176.0 .db 0x1C ; 9.8 192.0 .db 0x1C ; 9.8 208.0
Car: An Ol Buick
Engine: Vsick
Re: vette bin spark table
20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0
20.0 20.0 29.9 29.9 29.9 29.9 27.1 26.0 23.9 20.0 20.0 20.0
20.0 29.9 40.1 38.0 35.9 34.1 34.1 28.1 26.0 23.9 20.0 20.0
29.9 34.8 40.1 40.1 40.1 38.0 35.9 32.0 29.9 26.0 22.1 20.0
41.1 41.1 41.1 41.1 40.1 39.0 38.0 35.2 34.1 28.1 22.9 21.1
43.9 43.9 43.9 43.9 41.8 41.1 38.0 34.1 32.0 28.8 25.0 23.9
46.1 46.1 46.1 46.1 46.1 43.9 41.1 41.1 39.0 28.8 25.0 23.9
48.2 48.2 48.2 47.1 46.1 45.0 43.9 41.1 38.0 30.9 28.1 26.0
48.2 48.2 48.2 47.1 47.1 46.1 43.9 41.8 36.9 30.9 28.1 27.1
48.2 48.2 48.2 47.1 47.1 46.1 43.9 41.1 35.9 30.9 27.1 25.0
48.2 48.2 48.2 47.1 47.1 43.9 43.9 38.0 29.9 27.1 25.0 22.9
47.1 47.1 47.1 46.1 41.8 41.1 38.0 30.9 26.0 22.9 22.9 22.9
47.1 47.1 47.1 45.0 40.1 39.0 38.0 30.9 26.0 23.9 23.9 23.9
47.1 47.1 47.1 45.0 40.1 39.0 38.0 30.9 27.1 27.1 27.1 27.1
47.1 47.1 47.1 45.0 40.1 39.0 38.0 33.0 33.0 33.0 33.0 30.9
47.1 47.1 47.1 45.0 40.1 39.0 38.0 35.2 35.2 35.2 35.2 35.2
Re: Re: vette bin spark table
Originally posted by Grumpy
ARAP
ARAP
Car: 1983 G20 Chevy
Transmission: 4L60
Carb distributers can run over 50* by the time you count initial, vacuum, and centrifical in certain situations. My TBI 312 runs 45 in some low load higher RPM cells (think highway speed coast).
HoosierinWA
Oct 7, 2015 10:15 AM
