S_AUJP SA and Vortecs
Car: 1991 Camaro Z28
Has anyone tried running the spark tables from Traxion's SUJP with Vortec heads? I'm running it now and it seems to work well. I had to take a degree or two out at WOT but other than it seems ok. I haven't done a lot of testing with it yet though. From the reading I've done on here Vortecs seem to like a lot of timing down low and not much up high. Looking at the SA table from SAUJP seems to reflect that. Any thoughts about the viability of using it. I know tweaking will be required with any prebuilt SA table but it seems to work well.
Thanks,
David
Thanks,
David
Car: 1991 Formula
Engine: 355 with ported & polished vortech heads and a 269 cam.
Transmission: 700R4 (w/ shift kit) and 2000 stall TC
ironically, i'm working on that same thing right now. I can't seem to get my top end where I like it though, just feels like i'm missing something. bottom end does like a lot of timing though.
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
I'm building a vortec 350 with TPIS miniram III now. I'm starting with the same bin file.
I'd like to know your progress.
My engine is back in car, but the car is about 6 months from driving. Lots of body work to do.
Car: 91 Firebird
Engine: 6.0
I pulled about 5* of timing from all the tables and started from there. I find my motor doesn't want a lot of timing anywhere.
I *think* I'm running a total of 29* at wot, and perhaps 33-35* at part throttle
I really don't know what I'm doing when it comes to programing, but the car likes what I've done to it so far
-jason
-jason
Car: 1981 Buick Century Wagon
Engine: 87 GN engine
Transmission: 2004R
playing with the timing on a ortec headed 350 too. Using a 7747 $42 mask and tbi though. I have yet tom find this infamous vortec SA table though. Could someone point me in the right direction??
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Search under vortec and timing table, should get u to it.
I know Rbob has posted the iron headed Impala LT1 tables(kissing cousing to vortec heads and which there were derived from for the most part)
I'm not sure if we ever got a table from the 96-98 trucks though?
later
Jeremy
later
Jeremy
Car: '90 Formula
Engine: L98 --> Ramjet
I believe this is the thread you're looking for -
https://www.thirdgen.org/techbb2/sho...ghlight=vortec
Transmission: 2004R
Thanx guys, I was on that thread. Im guessing that is the one everybody is using, the second SA table posted by JP.
Chas91Z28
Oct 22, 2015 10:12 AM
monte87cortez
Sep 26, 2015 08:10 PM
