Can someone give me a good explaination of VE and also the Base Pulse VE vs RPM table??
Quote:
I dunno how *good* this is, but it's what I *use*. VE is volumetric effiecency. Or how well the engine is being filled with air, as compared to what it's possible potential is. It also is an pretty good indicator, of engine load.Originally posted by ostrich
BPW vs RPM, is an adder. It allows for a very simple way of expanding the main VE table to the higher RPM ranges.
Thanks Grumpy. How do you calculate the VE of your engine?
I don't. Originally posted by ostrich
It's implied.
By watching the WB, and tuning for Stoich., I develope the VE table entries.
When I'm tuning, just so that I have an easy picture in my mind to work with, I just consider it a BPW Table. Then when all is said and done, I look at it as being VE, and look for points of interest.
