how do i burn chips using auto prom
Old Sep 20, 2005 | 07:27 PM
turbotater's Avatar
i am used to using pocket programmer , now a friend brought
his auto prom over to try .
i have downloaded the software & drivers . but the instructions are a
little lacking for me .
1. i connected the auto prom unit with the usb cable
2. i opened tuner pro
3. i opened a bin from my tunercat program i use
4. it has note in the tool bar " no xdf selected"
what are the steps i need to do from here to burn this bin
toa 27sf512 chip ?
mike
Old Sep 20, 2005 | 08:33 PM
JPrevost's Avatar
Car: 91 Red Sled
I use the Flash & Burn software that is also ment for the BURN1. Make sure with the sf512 chips that you erase them BEFORE writing too them. How I do it; I erase them, do a blank check, then program, then verify. It only adds seconds to do the above and this way I know a chip is good. The sf512 is an eeprom, NOT a flash prom. Flash proms like the 29C256 can be programmed without having to erase but they cost a dollar more and aren't as big.
Old Sep 20, 2005 | 11:48 PM
Z69's Avatar
Z69
Use the XDF select up in the tool bar and pick an xdf that matches your mask.
Do the same for the bin selection.
If you don't see the AP as attached in the lower left.
Then select tools and "Initialized Attached Hardware"
Then in tools select Moates I/O.
You should be able to get it from there.
I don't have my AP here so I can't go any farther.
I can't "say" what buttons to push.
Old Sep 21, 2005 | 12:55 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Help
I was reminded recently that there is a nice "help" file within TP
Old Sep 21, 2005 | 04:02 AM
turbotater's Avatar
where can i find a list of these "xdf " files
i am not seeing them on moates web site
Old Sep 21, 2005 | 07:38 AM
turbotater's Avatar
it is working now . the driver was not working
it was being renamed automatically and it took
a while for me to figure out . then it took a while
to find a mask code to work on a 7747 ecu . then
a minute to figure out dip switch positions on the
auto prom unit . then a minute to get the start and
stop position right on the chip and buffer settings .
luckily there is a lot of info out there in different
places if you look for it enough to get things going .
thanxs for help guys
Old Sep 22, 2005 | 04:18 AM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Maybe post your procedure here now for someone else's future reference, if you feel like it.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
BumpaD82
Feb 26, 2016 02:57 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
