ALDL Connector ?
Old Sep 23, 2005 | 03:51 PM
yager's Avatar
Car: 1997 Jeep Wrangler
Engine: 2.2 L61
Transmission: R150/AX15/Toy T-case
Axle/Gears: 5.29
ALDL Connector ?
I have a new to me '95 Chevy truck and I wanted to hook up my Autoprom to do some basic diagnostics etc.. Based on my research the '95 is a OBD1.5 and is really obd1 with an obd2 sized connector...
I realize i can simply clip/pin on the wires, but i have a nice ALDL cable and interface with my Moates kit..
Can I simply get an older ALDL connector and rewire mine under the dash to match the older pinout ?
And for those who care.... my jeep TBI conversion is progressing slow.. Id say slower than expected, but im not on a timeline Shortened harness is in place but got side tracked with new seats, beefing the tranny mount and crossmember and a recient decision to revamp the older fuse block to the Camero block to make use of additional/discreete fuses for the ECM stuff.
Thanks for any help..
-mike
Old Sep 23, 2005 | 03:57 PM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
Mike,
For your 95, I have the 'CABL2'. If you want to swap your CABL1 piece that comes with the APU1 for a CABL2, that's no problem at all. Or, you can pick up a CABL2 from me for like $30. That'll at least keep from hacking stuff up.
-Craig
Old Sep 24, 2005 | 11:59 AM
yager's Avatar
Engine: 2.2 L61
Axle/Gears: 5.29
Craig i truly appreciate the offer, as luck would have it when i finally crawled under the dash its got the older/smaller connector, the truck has a 2/95 build date so that probably explains that..
I need the smaller aldl hood to fit the jeep project..
91 SrS
Oct 7, 2015 04:32 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
