Aldl Cable and PC config questions (newb)
Car: 86 IROC
i was looking over the guidebook at the configurations for running the ALDL cable with a laptop i have a newer laptop (no serial connections) but for a school project (homebrewed mp3 player {not alot of fun let me tell you}) i picked up a PCMCIA card slot serial adapter i was wondering if this should work or should i pull my old laptop out of the attic and repair it?
aslo my car is 86 305 TPI what cable shematic should i follow i looked at all 3 not really too sure....... im in the process of getting the materials to start doing my own tuning figured the aldl cable should be the first at least that way i can run tunerProRT and see some stuff happening
thanks
thanks
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
https://www.thirdgen.org/techbb2/sho...hreadid=275994
This was another recent post on it here. Hope something there helps u out
later
Jeremy
later
Jeremy
Car: 86 IROC
the old laptop i have is a PIII 700mhz nothing major, my girl friend is using it now in grad school.
Back on topic i stopped by my buddies garage tonite and borrowed just his obd1 connector and power cable for it.... if i just take a serial cable and hook it up whats the chances of it working? it should save building one.... really not sure. i wouldve borrowed the entire scanner but he might need it and told me i could have the connector cause he barely ever uses it
scratch that idea took a better look at it now its using a game port connector, going to try to build the 2 transistor cable tomorrow in class (gotta love college) and then ill try to make a nice connector for it
Car: 86 IROC
Ok i did alot of research today.......... going to build a cable so thas taken care of.....
does anyone know if either a usb to serial adapter will work if i tap power from the car itself or the pcmcia cardbus serial adapter will work?
