w2k or win xp compatibility with tuning/scan soft\hardware?
Old Nov 10, 2005 | 11:23 AM
drive it's Avatar
My old laptops are giving it up, so I've been shopping for a couple of new ones. May have to settle for used/newer to me.
Of course first concern is finding ones that still have a com and parralell ports!
I've been using win98se without any problems with tunercat, rt tuner, pocket programer, pocket romulator, fjo wideband, and tts datamaster.
I remeber some folk have said they've run into various problems wither newer O.S's. Has anyone run into problems with the above under win2k? Or XP? I'll probably stick with win2k, but would like to know about potential problems with xp also. If need be though I'll reload win98se.
I'm also using diacom+p, but I'll con't to run that with another ancient 486 under dos.
Thanks for any help!
Old Nov 10, 2005 | 04:39 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
windows 2000 is good to go.. I've used Datamaster, TunerPro RT, and PPII software.. All good... Turn off any infrared ports though..
Old Nov 10, 2005 | 08:10 PM
liquidh8's Avatar
Car: 1981 Buick Century Wagon
Engine: 87 GN engine
Transmission: 2004R
i us XP with tuner pro rt and autoprom, no probs
Old Nov 11, 2005 | 04:32 AM
Z69's Avatar
Z69
Same
Any problems will most likely be PC specific.
A driver conflict or something.
Old Nov 15, 2005 | 11:39 AM
86and96's Avatar
Car: 86 Camaro, 96Formula
Engine: 383HSR, 350LT1
Transmission: TH350, T56
I have been using a Dell Inspiron 600m with XP home for almost a year now with TunerPro, an Ostrich, and a homemade two trans ALDL cable with no problems. I have also been using it to download the LM-1 logs with no problems.
The Dell 600m is one of the VERY few laptops you can still get with a serial port and parallel port.
Old Nov 20, 2005 | 09:49 AM
Mark A 91Formula's Avatar
Car: 91 Formula
Axle/Gears: 10 Bolt 3.23
Been awhile but I had a serial pcmcia card for my laptop, and win2k didn't have support for 32bit pcmcia devices or some damn thing. Worked fine under 98 and xp though. Onboard ports worked just peachy though.
Hotrodboba400
Dec 10, 2019 07:07 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
sjorgens
Oct 1, 2015 07:54 PM
dbrochard
Sep 25, 2015 04:56 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
