AE MAF Tuning -- did search but have practical questions
Old Nov 14, 2005 | 12:47 AM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Hi guys, I am currently getting into fine tuning the AE on my 6E MAF Stealth Rammed 327. I have read posts on the subject but still don't know what exactly I should start modifying in the 5 AE tables. I am told I need more AE due to the stealth ram's large plenum volume. Now that I have my over rich idle leaned out, lean AE has reared its head, even free revving the car from idle. I am especially interested in any work people have done with MAF Stealth Ram or similar larger than stock plenum setups.
Old Nov 18, 2005 | 12:03 AM
Car: 2000 BMW M5
Somebody must be messing with AE in MAF. Heelpp!!
Old Nov 18, 2005 | 12:54 AM
Z69's Avatar
Z69
There are a couple of stickies IIRC for the 165 ae stuff.
Seemed straight forward when I looked at them.
You might try emailing the moderator Glenn if you get stuck.
Old Nov 18, 2005 | 11:55 AM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
i think i found some info in one of the threads here, and saved a snip of the text. I have to dig it up, so bear with me, its on my memory stick at home, so I might not reply for a day. But I recall someone posted the changes they needed to convert to an HSR, and posted the critical parameters, etc, as far as AE, and that kind of stuff. Keep digging though, I got from a thread here, but i dunno what i searched on, so it is here somewhere.
Old Nov 18, 2005 | 12:09 PM
Car: 2000 BMW M5
jws I found the thread about what someone changed to go to HSR, it is still on the board. The changes they made to the pulse correction seemed wrong though -- the stock values are all .5 and they listed values in the 3.xx range. Who knows though, I can try what they posted and see what happens
Old Nov 18, 2005 | 12:34 PM
JPrevost's Avatar
Car: 91 Red Sled
Did you increase the "Max airflow vs RPM" table by about a factor of 2? If not, do it, this can cause a lot of low RPM AE problems with free breathing engines.
Next, I set all of the "AE %BPW factor vs async" to 0.5 . From that I would just play with the AE tables until you get a wideband and can do some real good comparisons of the AE. The stock AE code with the $6E is pretty good and doesn't require much tweaking, even on modified motors.
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
NBrehm
Aug 25, 2015 11:49 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
