Getting started With an Ostrich and ALDL
Old Nov 21, 2005 | 03:06 PM
86BirdSE's Avatar
Car: 1986 Pontiac Firebird S/E
Engine: LG4 TPI Conversion
Axle/Gears: 3.42 SLP Posi 10 Bolt
So I've spent the better part of two hours reaserching and reading....
And for simplicity's sake... is it possible to begin serious tuning on one vehicle with:
1.) An ostrich to tune without burning seperate chips
2.) an aldl cable to log data (so I know what to change)
3.) my laptop equipped with TunerPro
This vehicle is a Typical small cam upgraded, ported stock head stock TPI Intake/runner/injector 350/700r4 combo, using a 730 ecm, and AUJP memcal.
Old Nov 21, 2005 | 04:54 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Seems to me you have everything u need.
Do some datalogging and familiarize yourself with everything before u change anything.
The stickies up top have excellent intro articles especialy for the $8D stuff
later
Jeremy
Old Nov 21, 2005 | 05:53 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
You think that thing would come with directions by now. Read the stickies or the manufacturers site.
Old Nov 21, 2005 | 09:28 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Just make small changes and prove the result happened due to your change. Making changes without proving/disproving the reaction is shooting in the dark. Try to understand the problem you are attempting to fix, search for some guidance here and make the change. Again, look for the result. If it doesn't surface put back the value and look at another variable to solve the problem.
Start with the VE tables to get the BLMs in line then maybe add some spark and do the VE again. Once your pretty satisfied with that move onto that off idle bog AE then into PE modes of operation. Keep trying to find out what works best.
You're on your way
Edit: Keep making copies of your altered bin as you make changes. With emulators it is extremely easy to loose track of what was working best as you keep tweaking values.
Old Nov 23, 2005 | 12:40 AM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
You mean like this?
http://www.moates.net/documentation....entation_id=24
Old Nov 23, 2005 | 12:58 AM
86BirdSE's Avatar
Originally posted by Craig Moates
You mean like this?
YES... ahh thanks Craig!
chazman
Aug 28, 2018 03:25 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
chazman
Aug 22, 2015 02:01 PM
355tpipickup
Aug 19, 2015 10:02 PM
