7747 question????
7747 question????
Installing TBI in my 89 Jeep Grand Wagoneer and have a question. Have everything hooked up, but have no fuel pump. I have injector pulse, and spark, and can make it run if I jumper the fuel pump, but ECM is not turning on the relay. Acording to my information, the controller sends a 12V signal to the relay to actuate it, which I am not getting. Checked at the relay and controller. Nothing!
So I guess my question is what does the controller need to see to send the 12V to the relay.
Thanks in advance, Andy
Car: An Ol Buick
Engine: Vsick
Re: 7747 question????
Yes, it sends 12v to the relay winding, and the other side of the relay winding is grounded. If you have power *out* of the ecm to the relay, and no pump then it would seem there's a broken wire, a bad relay, or no ground for the relay.
Re: Re: 7747 question????
Originally posted by Grumpy
The power out, is only for ~2 secs., when you first go key on, then the power for the pump comes from the oil pressure switch.
Car: check
Engine: check
Transmission: check
Re: Re: Re: 7747 question????
Thanks for the reply. I do not get the 2 sec prime. Checked it at the ECM.
RBob.
