tunnerpro rt/ostrich any good? pros/cons
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
hi i have been dataloggin for a bit now using ecm852 with a old laptop...i just got a newer USB laptop and i want to get tunner pro rt and the ostrich..how do you like the ostrich and tunnerpro and is it worth it? is it user friendly? i dont know much about burnin yet but im very willing to learn!! any info/help is needed thanks! also what else is needed for this to run and work on my motor?
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: tunnerpro rt/ostrich any good? pros/cons
-- Joe
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
Re: Re: tunnerpro rt/ostrich any good? pros/cons
Originally posted by anesthes
Tunerpro and ostrich is a nice combo. I went to it this past fall, and it makes tuning so much easier. You can dial in idle in a few minutes, and with a partner get most of your VE work done in an afternoon.
-- Joe
-- Joe
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
It is worth every penny of the price in the time it saves while getting the tune dialed in.
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Craig...we got the "0" back and it works awesome
Thanks a ton.
Thanks a ton.
Car: 92 1500p\u 2wd
is this a good thing to use if its your first time tunnin at all? i dotn know much at all about tunnin yet...but im lookin to learn. not sure if this is the best setup to start with!!
Yes!! Its much easier than the traditional way of pulling and erasing chips and getting all messed up about offsets etc..
The 'O' is truely plug-n-play-n-burn rubber..
And you will not get better service than what Craig provides if you run into problems.
Car: 1986 Trans Am
Engine: Carb'd 305
Axle/Gears: 10 bolt, 3:42's
I'm interested in getting one of theset too, but I'm wondering, do I need to get an EEPROM for this to work right or does my regular eprom work fine?
Thanks,
Shawn
Thanks,
Shawn
Car: 86 Monte SS
Engine: LS2
Transmission: 4L65E
Originally posted by Craig Moates
Haha!
The "O", that's pretty funny:
http://www.moates.net/zips/oface.wav
Haha!
Ghettobird52
Jul 5, 2024 11:18 PM
