$6E Spark Retard
Old Jan 26, 2006 | 03:18 PM
HowdyDuty's Avatar
Car: '84 Chevy 1500
Transmission: TH350
$6E Spark Retard
Hey,
You know the startup spark advance table? If I put in a value of 6 at 90 degrees, that'll give me 6 more degrees of spark advance during crank right? So if I put in -6 at 90 degrees, will that give me 6 degrees of spark retard for easier hot starting?
-HD
Old Jan 27, 2006 | 06:24 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
When cranking the timing is always at the base or initial setting. This is what the districutor is physically set to. The ECM SA tables are only used once the engine is running.
RBob.
Old Jan 27, 2006 | 09:35 AM
HowdyDuty's Avatar
Car: '84 Chevy 1500
Transmission: TH350
Then what's the "startup spark advance vs. coolant temperature" table for then?
-HD
Old Jan 27, 2006 | 10:20 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
-HD
Have a table address?
RBob.
Old Jan 27, 2006 | 10:49 AM
Vader's Avatar
18d -> 19a
Old Jan 27, 2006 | 11:31 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Originally posted by Vader
18d -> 19a
The table at this address is SA added at engine start time. It is decayed out over time. Sometimes referred to as choke spark, the purpose is to help keep the engine running during the first several seconds (or a bit longer when cold).
RBob.
Old Jan 27, 2006 | 02:16 PM
HowdyDuty's Avatar
Car: '84 Chevy 1500
Transmission: TH350
Oh ok. Thanks!
-HD
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
