target air fuel ratio
Old Feb 14, 2006 | 11:46 PM
walterrao's Avatar
Car: 91 RS
Engine: vortec 355 hsr
Transmission: wct5
Axle/Gears: bg3.27
my question is if i add or subtract fuel from the VE table the ECM will simply add BLM's to keep the AFR at 14.7:1 right??
... And if so how do i change the ecm's target AFR. I am using CATS tuner V.2.08 And have a tbi 8746 ECM
Old Feb 15, 2006 | 11:49 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: target air fuel ratio
Target AFR will be 14.7: in closed loop everywhere but AE/PE.
Target AFR will also be nothing close to true AFR
-- Joe
Old Feb 15, 2006 | 03:51 PM
Ronny's Avatar
TC told me that you can alter the A/F somewhat, a little, in the constants. it is the stoich A/F in constants. i have no emmishions so i moved it to 14.3 for CL. now i am running OL as an experiment 1/2 of last season at 122-126 blms in tune and on WB it is like 14.00-14.500 cruising and 13.00/1 at idle. seems to like a rich idle. idle exhaust has no odor and is clean. tip in improved too. overall drivability is better. fuel mileage may not be.
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
mdtoren
Aug 23, 2015 12:52 PM
