another one trying to tune $59
Old Mar 2, 2006 | 08:16 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
hey guys i'm running the $59 32k bin with wideband, i have 30lb/hr injectors on my 305, i'm using the ads from nwstp.com the 2&3bar ads, the idle injector pw are around 5-6ms is something wrong with the ads? i thought i read that somewhere, i'm using a bpc of 111.00 right now, the mixture seems to be okay, i'm waiting to recieve my wideband o2, but 5-6ms doesnt sound right, also why does $58 have soo much IAC stuff, my idle is not smooth, i got it better but it's hunting about 75 RPM, i need to get this tuned for my procharger thats sitting in the box or it's back to $8D and an FMU
Old Mar 2, 2006 | 10:55 AM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
I'm pretty sure the bpc vs egr should be 138 for 30 lb injectors. it doesn't matter what the pulse width is as long as the AFR is good. you don't have the wideband yet, so... are you using the stock O2 with some sort of wideband patch? could that be messing up some readings? If your WB patch is the same I have, it doesn't change tuning, just the datalogging file includes the WB readings.
Old Mar 2, 2006 | 01:23 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
the stock typhoon bin has a bpc of 130 which is for 30lb/hr injectors, i'm way rich with that setting, i used the bpc calc on moates to come up with my current value, i'm using the stock o2 sensor for the time being, i'm just focusing on my idle right now. i'm using the $59 bin off of moates, i guess it has the EGR fixed, it's upped from 16k to 32k and it has the flags to use wideband o2's which is just for the datalogs i would assume. i'll try the 130 bpc again, another question should i leave the ve vs rpm table alone and just change the values in the closed throttle ve table?
it seem to run alot better at idle by lowering the ve vs rpm from 30.86 to 20.50
Old Mar 2, 2006 | 01:24 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
There is a bug in the ADS. I was whining about it a few months ago. The fix is to change the ADS file values. Do a search for my username and $58. The complete fix should come up.
I had a reported 5-6ms BPW at idle..that is really in the 1.5 to 2.0 ms range.
Is that $59 bin released to the public?
Old Mar 2, 2006 | 02:44 PM
Z69's Avatar
Z69
Yes,
It's part of the CL WB code requirement thread I thought.
If not, a search on 1981TTA & WB code should turn it up.
It's on Moates I think.
Old Mar 2, 2006 | 04:33 PM
1981TTA's Avatar
Car: 81 Turbo Trans Am
Engine: 301 T
Transmission: 200-4R
Re: another one trying to tune $59
Originally posted by 86Z
... why does $58 have soo much IAC stuff, my idle is not smooth, i got it better but it's hunting about 75 RPM...
I don't know if this was fixed with your VE change. If not, have you tried zeroing out the idle RPM error spark tables? I know these tables have caused problems on other's vehicles, too.
Old Mar 2, 2006 | 04:38 PM
1981TTA's Avatar
Engine: 301 T
You can find it on Moates site under the "Custom Binaries" section. The full name is $59_05202005.zip. But, I think you only see _05202005.zip in the listing. If/when you try to download it, you'll see the full name show up.
Old Mar 2, 2006 | 06:31 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
no the idle has not been fixed yet, are you referring to the F89 table?
Old Mar 2, 2006 | 08:05 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
hey junkcltr, i found your post and got a headache from reading all that math what exactly was the fix? i dont know how to go about adding that stuff to the ads or changing it, if we have a fixed ads file, someone should upload it to moates.net
Old Mar 2, 2006 | 08:17 PM
junkcltr's Avatar
Engine: 3xx ci tubo
All the goofy math was posted because I was new to TP4.0 and didn't know what I was doing with it. I won't upload it because I didn't create the file so I don't feel I have the right to upload it. Send me a PM I will see what I can do.
Old Mar 2, 2006 | 09:30 PM
1981TTA's Avatar
Engine: 301 T
F88 and F89. Zero out both of these and see if it helps your idle.
Old Mar 4, 2006 | 02:53 PM
skwayb's Avatar
Car: 93 GMC Typhoon
Engine: 4.3L V6 Turbo Charged
Transmission: 4L80e
I am going through the ads and xdf on nwstp.com. I hopefully I will have those bugs worked out of them. If you see anymore like that.. please post it. We took the base one that came with Tunerpro and have been adding/fixing things that are in there. I am sure there are more. even when you put in the informachine from the ds definition file (think it is 160.ds) some of the values are still incorrect. I guess I will have to look at some logs in datamaster and compare them to what the ads says they are in tunerpro.
Old Mar 4, 2006 | 04:07 PM
Z69's Avatar
Z69
The divide calc in the ads slips by people a lot I think.
And doing the whole ads is very time consuming.
Zell1luk
Sep 29, 2015 10:36 AM
