EBL and WB02s
Old Apr 29, 2006 | 01:08 AM
TierAngst's Avatar
Car: 78 Caprice Coupe
Engine: 355
Transmission: 4L60
EBL and WB02s
I always hear/read about people buying these really expensive WB02 kits, is anything besides the sensor itself needed for the EBL? Can I just plug it directly into one of the ports and have the data come up on my laptop when using the WUD? The sensor itself is like $80 where as the kits are around $400, right now $80 is do-able. I have zero knowledge of WB's but I was hoping to start out with good news like "sure you can use just the sensor just hook it up like so"
Old Apr 29, 2006 | 07:39 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
You need a controller. There are ones less expensive then 4 bills. I believe the LC1 is < $200. This is a basic controller and sensor, no display. That is all that is required when data logging.
RBob.
Old Apr 29, 2006 | 08:42 AM
TierAngst's Avatar
Engine: 355
Transmission: 4L60
Definitely better than $400 but I'm still going to have to wait a bit, I will get one before I do the cam swap though since I want to get some experience with it before tackling programming a cam change.
antman89iroc
36
Jan 31, 2016 08:42 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
Quzyle
Oct 15, 2015 03:35 PM
92rsvortec350
Sep 16, 2015 09:12 AM
85Special
Sep 3, 2015 04:21 PM
