Just bought...
Old Apr 30, 2006 | 07:37 PM
JayBoCC2's Avatar
Car: '88 trans am GTA
Engine: 5.7L 355 TPI L98
Axle/Gears: eaton posi 3.73 gears
Just bought...
i just bought a pocketprogrammer 1 (not 2) and a dataraseII for $140 im just wondering if it was a good deal or if i should figure out a way to kick myself in the behind. thanks... im new to this stuff. fyi i want to use it to program my 88 trans am gta. will it work? if so will chips 27SF512 work with it?
Old May 3, 2006 | 08:55 AM
50chevyrod's Avatar
Car: 1950 Chevorlet Pickup
Engine: 405 Pontiac
Transmission: 4 spd m22
Axle/Gears: 8.5 10bolt 3.95:1
I don't know if those chips will work but you could always go to a junk yard and pull stock chips yourself.
Old May 3, 2006 | 11:00 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Chips should work fine for you.
Your either going to have to stack the bins or offset burn them.
Do a search on those terms and your chip and you should find lots more answers.
Also in the stickies above.
later
Jeremy
Old May 3, 2006 | 12:08 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Another note: you'll need an adapter to use those chips (27SF512). You can use either a G1 or G3 from Moates.net for your ECM (1227165).
M
Old May 6, 2006 | 08:16 PM
JayBoCC2's Avatar
thank you two. Yea i know i need to get an adapter, and i plan on purchasing one, thanks for your help. My main concern was whether or not the 27sf512 chips would work because of the funky voltage required to clear the chip.
jrhaus76
Members Camaros
362
Apr 11, 2019 09:47 PM
tomtom89
Sep 1, 2015 03:35 PM
jrhaus76
Oct 27, 2008 10:39 AM
Bullydawg
Members Firebirds
Feb 18, 2008 01:57 PM
flaminbird 84
Mar 1, 2007 03:20 PM
