startup spark
Old May 11, 2006 | 01:27 AM
michal_larson's Avatar
startup spark
what time table does the 7747 computer use to start engine? does it start at 400 rpms (21 degrees) plus the value of "startup spark added", or just the main spark map.
Old May 11, 2006 | 01:40 AM
info on my setup base timing is set at 10 degrees, spark map starts at 16 degrees, ive been setting my "startup spark added" but not much difference.
Old May 11, 2006 | 07:31 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Cranking and running until the 'engine run RPM' is reached is at the base timing.
RBob.
Old May 11, 2006 | 02:22 PM
so, its just "base" used to start the engine, and once it starts it uses the spark map plus "startup spark added"?
Old May 13, 2006 | 04:53 AM
m2c's Avatar
m2c
Is the startup spark biased with some value like the coolant compensation table is? Or is it just added to the main spark table?
Old May 13, 2006 | 07:11 AM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
If you mean CRANKING spark, it's JUST base timing, and absolutely nothing else.
STARTUP (after rpm is greater than 400 rpm) has a startup spark adder, and coolant vs load adder (biased against it's offset), and main spark table. If your xdf is set-up properly, it's just add the 3 numbers together.
Old May 13, 2006 | 07:19 AM
m2c's Avatar
m2c
Thanks alot for fast reply. It was exactly that info i was after.
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
