lm1 log of rpm/map with air fuel ratio exported into grid
how to do? i want to log 25 minutes of air/fuel/map/rpm with LM1 in OL and place log into a graph that looks like winALDL cept the blms will be lambda values. then do a few more runs same level course to see consistency. then adjust my fuel tables accordingly. i do understand i can run my WB02 in place of NB02 but unsure how to wire to ECU. i suppose i then can command stoich or rather 14.00/1 vs 14.70 or any other A/F but waana try this first.
right now in OL i am running 124 BLM. i just think the WB may be more accurrate and may only take one hit rather than 30 to get a good read. actually i might get 100x more than BLM hits. as it stands nnow i can graph to .10 sec or 1.0 sec per read. if i use 1.0 sec i will get a smoothened out graph.
wacky? any value?
wacky? any value?
1992 Trans Am
May 10, 2023 07:19 PM
