stupid but quick question
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
on the SA maps in tunerpro that is rpm x lv8 or is it rpm x grams/sec?
Car: z-28 x2
Engine: 355ci and 305ci
Transmission: th350 and th350
how is your combo running?
im building basicly the same 383 with the same rearend like you and i was wondering if your satisfied with it...or not.
thanks
thanks
Car: check
Engine: check
Transmission: check
RBob.
Car: '02 Z06
Engine: L33 5.7
thanks man! and i assume thats where the chart ends at 208, that means from there on, its all static? you cant play with any more timing with any lv8 over 208?
