250 knock counts bad?
Old May 27, 2006 | 12:03 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
weird thing tonight iw as logging and played around a bit and my knock counts jumped up to around 140 and later while cruising it jumped up again to 250! if i can figure how to post this datamaster recording to let others view, can someone please check this out for me? from looking at the chart, i can see that maybe its do to running too lean at that particular time? because the engine is only turning about 2500-3000 rpm but my blms are running around 150-160! my LV8 is running between 100-130 and inj bpw is from aruond 5 and dips down to 2.5 ish and such. but the DC is only showing 12-15% the whole time. anything else i can add to this to see why i got a spike of knock counts?
Old May 29, 2006 | 09:46 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
I had a time when I noticed my knock counts go nuts and started to climb. I couldn't hear anything yet I noticed the knock count just "adding" continuously.
So, I took it easy and drove home. By the time I got home, I could start to hear the knock and it turned out to be a problem in my valve train.
Bottom line, a high knock count that keeps "increasing" and wraps around may be an indicator of a mechanical problem.
Old May 30, 2006 | 12:46 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
it turned out a spark plug boot worked its way off the plug, so im blaming that, havnt driven the car yet since then so i havnt had a chance to datalog it yet.
Bubbajones_ya
Jul 6, 2024 08:32 PM
FormulasOnly
Sep 10, 2015 09:07 PM
john204481
Sep 7, 2015 03:22 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
tgp1990
Sep 4, 2015 06:24 AM
