i need some stumbling help
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
so with specs in sig, i cant get it to run right, it stumbles alot and what not, also got a maf high code, i raised all the maf values by about 10 points total that helped alot but i get the code.. is this because maybe the maf value is higher then the maximum air flow vs rpm? i dataloged a whole session if someone could give me a hint what to look for specifically? thanks in advance!
-also are blms's a direct reading from o2 sensor?
Car: An Ol Buick
Engine: Vsick
Yes.
Raising the MAF values in the MAF tables makes things richer. If you find yourself making whole sale changes you might dither with the Injector Constant.
Car: '02 Z06
Engine: L33 5.7
u think the stumble is a lean condition? i cant find any tables to do with ae (accleration enrichment) except for ae factor vs change in lv8.
edit: now i see some accel enrich vs etc... but nothing for what you say ae vs maf? and no ae vs tps? where am i missing this?
RedLeader289
May 28, 2019 01:47 PM
