Acronym meanings...
Old Sep 19, 2000 | 09:01 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
Acronym meanings...
I've been playing around with CATS, what's BLM and usec?
-Mark W.
<A HREF="http://www.angelfire.com/al3/thegreycar">'88 SC Camaro w/ 305 TBI</A>
Old Sep 20, 2000 | 01:40 AM
Dan W's Avatar
BLM is block Learn multiplier
It is Long term fuel trim. Values range from 0-255, 128 is perfect +/- 5 is where you want to be. The range of 0-128 and 128-255 are equal to 100% add or subtract fuel. High numbers add fuel due to a lean condition; low numbers subtract due to a rich condition.
How BLM works: One BLM value is stored in the ECM for each cell in the fuel table, and fuel is therefore modified.
How BLM is calculated:
The oxygen sensor constantly fluctuates back and forth across 450 or 500 mv (I forget which) the ECM counts these, you may notice a monitor named "cross counts" You should also notice the Sensor voltage as displayed fluctuating as I said, each of these values is added up and averaged using cross-counts... thus giving an indication of rich or lean, this value is represented as the "Integrator" or short term fuel trim again, a 0-255 monitor with 128 as the value that equates to 14.7:1 air/fuel ratio. BLM is Calculated from the Integrator.
Use BLM as your tuning aid for part throttle / idle closed loop operation. Use this value only when the integrator value is at or very near 128.
Old Sep 20, 2000 | 07:27 AM
Hank Brote's Avatar
usec is "Micro second" - the measurement of the time of a electrical signal.
Hank
87'IROC Z28
Hanks 87 IROC
polymer52
Nov 4, 2012 08:45 AM
pwdbychevy
Mar 5, 2004 10:56 PM
junkyarddog
Theoretical and Street Racing
Nov 16, 2002 12:59 PM
88SS6SPEED
Jul 24, 2000 05:39 PM
