Traxion a quick question
Old Oct 11, 2000 | 04:57 PM
slowTA's Avatar
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
You said that the hypertech chip is easy to work with, because the prom just slips in and out. Do other brands do the same??? I ask because there seems to be a lot of ADS chips on ebay. Anything to watch out for based on year/motor issues?
'86 TA, T-tops, T-5, 3.73, 4 wheel disks 350, compucam 2040, performer intake,SLP Headers, 3" race magnum muffler, 1.6 Comp rockers, Ripper shifter, perf. friction pads, Hypertech ignition, Earls brake hoses, Hotchkis springs, Tokico Illumina 5 adjustable shocks and struts, Lakewood panhard and trailing arms
14.73 @ 95... traction still a problem
Old Oct 12, 2000 | 08:01 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
I'm not sure. Has anyone here worked with an ADS chip of the MemCal design? I would think that they -are- of the same design as the hypertech because it saves them money. But, since I haven't actually worked with an ADS chip I can't say for sure.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.587 @ 107.97mph (1.710 60ftr) on the long runner setup.
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels. Stock Wheels. No Weight Reduction.
Gunning for NA 11's with the MiniRam II and Hooker LT Headers.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Old Oct 12, 2000 | 05:45 PM
slowTA's Avatar
Car: '88 Formula
Thanks anyway, I'll just have to call them and find out.
Old Oct 12, 2000 | 08:46 PM
Guest
Guest
Posts: n/a
The ADS has a different design than the hypertech, IMO its a really cheap setup, but it does work. And the chip is easily removeable. One problem I noticed is you can stick it in the ECM either way, there are no tabs to prevent you from putting it in wrong, so make sure you put arrows on it (they come that way, but its taped on).
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
