ALDL Cable
Old Dec 3, 2000 | 07:19 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
ALDL Cable
Well, more like the connector from aldl to the pc... I got the Max232ACPE is this the correct chip?
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Problems every other day with the car (probably not a mod, but to me it sure makes a difference)
Old Dec 4, 2000 | 02:30 PM
lars92RS's Avatar
Car: '92 RS
Engine: In pieces
Transmission: Built 4L60
I assume that you are trying to make a universal adapter for 160 and 8192 baud. In my scematic that I have handy it shows just a plain "MAX232" with no suffix. But there is a note that says if you use a MAX232A you have to change the Capacitor to a 0.1 uF and the pinout is different but the principal is the same. From what you write I think you have the MAX232A and I wouls ASSUME that all you need to do is make sure that your pinout is correct and use the different Capacitor and everytghing should be fine for you. If you want more info try this link. www.techedge.com.au/vehicle/aldl8192/8192hw.htm
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
