8d
Old Jun 23, 2006 | 11:58 AM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
8d
8D Does the coolant temp comp table effect idle. thanks
Old Jun 23, 2006 | 01:22 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Axle/Gears: 373
Who knows
Old Jun 23, 2006 | 03:13 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Yes. There is a target idle RPM vs. coolant temp. sensor (CTS) table for both drive and park/neutral.
Old Jun 23, 2006 | 03:18 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Axle/Gears: 373
sorry this is the coolant temp spark compensation table 8d
Old Jun 23, 2006 | 05:19 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
I only know of the "Drive" table and there is an adder for when in park.
Did I miss it somewhere or is mis-labeled?
I do know that the spark is reduced when cold. I'm dealing with that now trying to figure how to get a little more advance on the cold starts. Drops to like 19* instead of the 26-28* that I have when warm. As the temp comes up it is put back in, just have to do some more digging to figure out where to adjust this.
I'm thinking its the table at 813B but need to experiment with it a little to be sure.
Could also be the one at 81B9 messing with me.
Old Jun 23, 2006 | 06:43 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Axle/Gears: 373
Anyone else thanks.
Old Jun 25, 2006 | 02:59 PM
kyanox's Avatar
Can you elaborate on how this works, i'm trying to crack the 36 and need an idea of what the table might look like.
Does it use current idle and coolant temp to calculate the desired idle?
