quick question about ALDL interface cable
ok the chip that i have is a MAX232ACPE but the one in this diagram is a 232 and all the schematics/parts lists i see have the 232 not the 232A. the 232a is just a faster chip right? Do i need to make any changes to the board setup?
http://www.mindspring.com/~amattei/aldlif.jpg
thanks
Brandon
"ScreaminDeamin 360"
350 60 over, TRW forged 9.83:1 pistons, crane cam 216/228 .484/.512, crane 1.6 RR's, ported plenum, home made ram air, 19 lb SVO injectors, crane AFPR
(dont worry i am switching to the 89 ECM)
[This message has been edited by ScreaminDeamin85Z (edited January 18, 2001).]
thanks
Brandon
Car: '92 RS
Engine: In pieces
Transmission: Built 4L60
http://www.techedge.com.au/vehicle/aldl8192/8192hw.htm
Dude, check out this site, it explains the difference if you use 232A the CPE at the end designates Operating temp and other dimensional things that are pretty much arbitrary.
What software are you using with your cable???
later,
lars
later,
lars
