differences in 87 f-body and 89 y-body memcal?
Old Feb 9, 2001 | 12:29 PM
leirch's Avatar
Guys,
I as you have read messed up my previous memcal. Is there any difference in the 87 and 89 memcals? Thanks guys.
Brendan
1987 IROC-Z L98 350 SuperRam, Edelbrock Performer 6085 Aluminum Heads, LPE RollerCam 219/219, Crane Gold Race 1.6RR, TF 1 pc Moly Pushrods, Underdrive Pulleys, Edelbrock TPI High Flow Base Manifold, Accel 58mm TB, ADS 24#, Crane AFPR, K&N, Edelbrock TES Headers, Catco Hi Flow Cat, 3" Borla Cat-Back, Accel Cap & Rotor, MSD 8.5mm, MSD 6AL Ignition, MSD Blaster 2 Ignition Coil, Hayes Clutch, 1LE Aluminum DS, 94' Z28 Disk Rear, Wilwood Adjustable Proportioning Valve, Torsen Series 3 Posi Carrier, Precision 3.73 Gears, Southside Machine Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Old Feb 10, 2001 | 03:08 PM
leirch's Avatar
Come on guys, any help?
Old Feb 10, 2001 | 06:54 PM
Blade's Avatar
I dont think there are any differences. They should be the same. The only major difference was in 90 when SD was introduced. Why not just plug it in and see how it works ?
Old Feb 10, 2001 | 07:02 PM
leirch's Avatar
Blade,
Well for one i can't just "plug" it in. My car is an 87. The 89memcal/vette chip had vats so i'm going to have to desolder the chip out and put a ZIF socket in and then reprogram the chip but it would be nice to know if it wouldn't work due to the limp home mode chips. That way i can at the VERY least take it back and get my 45bucks.
Brendan
Old Feb 10, 2001 | 09:52 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by leirch:
Guys,
Brendan
</font>
Probably,
There is something odd going on in at times you can't run 89 code on a 87 memcal.
But, lots of folks have.
Silver Spear
South East Region
18
Dec 4, 2015 09:59 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
83 Crossfire TA
Sep 8, 2015 12:06 PM
RyanJB
Sep 2, 2015 01:27 PM
