Optimum air fuel ratios
Old Mar 27, 2001 | 02:39 PM
87Z-ya's Avatar
Ive been tuning with my speedpro for a while now and am curious as to what others think about air fuel. In my air fuel table I have idle ratios around 14.2-1 and my wot at torque peak around 12.7-1 leaning out to around 13.1-1 near hp peak. Cruise is around 14.0-1. I have heard many different things and have learned to give the motor what it wants. But shouldnt cruise ratios be around 14.7-1? I tried it and the engine just doesnt run as smooth. Also should wot ratios be richer?
87z 383,afr 190's, comp hyd roller(242/248-.540/.562,114 sep),Ported and polished mini ram, 30lb inj, 3.42 gears, tremec 5spd, , 1,3/4" slp headers, speed pro bank to bank-wb02.
"Just remember children, no man can beat you once youv'e found the cliterous." 'chef'
Old Mar 27, 2001 | 03:08 PM
pontiac's Avatar
-clip-
"..maximum power at an air fuel ratio of 12.6:1 or best fuel economy at 15.4:1, but for A/F ratios below or above these values no performance gain is achievable."
-clip-
http://www.holley.com/HiOctn/TechSer.../FMFITch2.html
http://www.mummbrothers.com/SRF_Stuf...e/Air_Fuel.htm
if you're running with cat, you should use 14.7 as much as possible.
hope that helps
Pontiac Trans Am GTA'89
CC1 GW6 G80 JG1 L98 MXO N64 WS6 822
Old Mar 27, 2001 | 07:52 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by 87Z-ya:
</font>
This is what tuning is all about.
Finding out what YOUR engine likes best.
**My calibration** uses 14.7 at idle to base all further corrections on that, ie highway cruise. At WOT uses 12.25, which I double checked with a WB, and Plug readings. Reguardless of what you do you need to veriify things with plug readings. WBs and K/Ss are fine for a pure stockl application, but you can beat them at times
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
mdtoren
Aug 23, 2015 12:52 PM
