reading hypertech 126 002 prom
Old Jul 20, 2006 | 06:22 PM
busta9876's Avatar
Car: 1967 C10 Pickup
Engine: LMM Duramax
Transmission: 4L80E
I tried to read a hypertech 126 002 prom today, the number on the chip says 27256 so i set my programmer to those settings and read it.
32K file,
CATS Tuner says: Selected source file is either corrupt or an unrecognized format.
anyone know what I need to do? does hypertech change them around so we can't read them???
thanks
Brendan.
Old Jul 20, 2006 | 06:32 PM
HaulnA$$'s Avatar
32K file,
thanks
Brendan.
Did you have the programmer setup to save it as a binary file? I know I use my burner for work stuff sometimes which is all Motorola Hex and I always forget to set it back to binary. Just a thought. HTH
Old Jul 20, 2006 | 06:56 PM
busta9876's Avatar
Engine: LMM Duramax
Transmission: 4L80E
it reads stock PROMS just fine, I used the hedder adaptor on a Wellim programmer, and read the MEMCAL directly. works great on stock ones.
I tried 27C256 settings, no dip change, but it changed some of the memory speed settings, but i read it, verified the read, and tried again,
this time CATS tuner said it was a $77 Definition, is this somthing Hypertech does to prevent people modifying their chips?
Old Jul 24, 2006 | 02:20 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Hypertech likes to protect their "propreitory" tuning. I'll save you the time and effort and tell you they disable EGR, speedlimiters, add a few degrees of timing and crank up the fuel a bit at WOT. At least that's what they did with the older TBI chips that I've looked at. Most of these were done way back when they weren't protecting their chips.
Bubbajones_ya
Jul 6, 2024 08:32 PM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
ChristinaMarie
Sep 11, 2015 06:28 PM
86IROC112
Sep 11, 2015 04:04 PM
