Tuner Cat question-- "LV8"
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
The LV stands for Load Variable but I'm not sure what the 8 means. From what I know, Diacom gives its units in grams/cylinder, meaning the amount of air taken in by each cylinder, and this is a calculated value using airflow and RPM and probably other data. It's similar to the MAP reading on speed density ('90-92) cars but not identical...
Greg Westphal
'87 IROC 305TPI/A4
Greg Westphal
'87 IROC 305TPI/A4
LT1Formula
Oct 8, 2015 08:34 PM
