I figured I would post this here, because alot of you deal with Diacom.
I have an '86 T/A with a TPIS Miniram, and TPIS's "90 and up Vette Computer" along with the "Level VI PROM"
I've tried linking to the computer, but all I get is the "Linking...." message and no data.
I've tried "Diagnostic" "Normal" "ALDL" modes with no luck. I've configured my computer to run on the slow setting. All my parallel ports match. I've tried both connectors, and even the optional parallel cable power cord with no luck. I used a dummy VIN in order to show the proper fields for a '93 chevy 5.7 with no luck. I've tried several different VIN combinations including my original VIN with still no luck.
I'm at a loss here guys, any ideas?
Thanks,
86 Trans Am WS6 Black with tinted windows, shaved door handles
ZZ4, Mini-ram, true duals
***Too many other mods to mention***
"In the future, cities will become deserts,
roads will become battlefields, and the hope of mankind
will appear as a stranger" The Road Warrior
[This message has been edited by Steves ZZ5 (edited April 04, 2001).]
Thanks,
So your saying your running a Speed Density setup then? I haven't heard of too many problems when hooking up to a SD setup if thats what your running. Maybe something is wrong with your cable?
You may want to contact Rinda(maker of Diacom) if you can't find any other help on this board.
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Brendan
