need some some help.........
Old Apr 8, 2001 | 10:05 AM
Z-BOSS's Avatar
alright.......
I've save the my old bin which is off an old hypertech chip. And I'm curious how to get the information to tuner cats so I can see what they did different from stock.
when I try to load the info. to tuner cats as a bin it's not showing up as a bin.
How do you go about doing this........
it's got me stumpt.
Old Apr 8, 2001 | 11:31 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by Z-BOSS:
alright.......
it's got me stumpt.
</font>
Find a compare utility, going thru table by table will take along time.
PS. usually not worth the effort anyway, for most aftermarket chips
Old Apr 8, 2001 | 02:14 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
The reason your Hypertech eprom may not be readable by TunerCat is because Hypertech may have changed the PROM ID to something other than its "stock" setting.
This is what certain "custom prom writers" do to make it difficult for you to use an editor like Tunercat to read their prom. This is generally because they don't want you to know what they have done or don't want you to make changes.
Regarding Hypertech, I can tell you that you will be sadly disappointed when you DO SEE what little they have actually done.
Grump's suggestion of using "Binary File Compare" is an excellent suggestion because sometimes prom writers also alter the actual instruction set which you can only see with a "file compare".
Old Apr 9, 2001 | 09:50 AM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
Can you recommend a binary file compare tool, and a binary file editor ? Unix or PC is fine.
Thanks!
