Failed Emissions
Old Apr 24, 2001 | 07:15 AM
im's Avatar
im
Failed Emissions
Hi guys, I failed the test yesterday.Everthng was ok except my CO reading.
HC=41....the limit is 68ppm(parts per million
NO=134...the limit is 751ppm
CO=1.33..the limit is .38ppm
This is pissing me off...I have a new GM(350) 300hp crate motor(2 years old), a 1 month old brand new CATCO converter. My timing is at 10 degrees. Did an oil change 1 month a go.Thinking of putting that Guranteed to Pass Emissions stuff in my gas tank the next time I go. Does that stuff really work??. My fuel pressure is set at 48psi. What gives ???...Any help would be appreciated. I have a Paxton supercharger also. but it is disconnected. I didn`t want to run it for the test.I have the stock setup
(air cleaner assembly with the dual air filters. After I took the test the mechanic said sometimes it is better to bring it in cold than warm up the engine(better chance of passing). I also read in the paper that if it fails at one place take it to another and it could pass. They went to 4 different places and 1 failed and the other 3 passed
[This message has been edited by im (edited April 24, 2001).]
Old Apr 24, 2001 | 08:40 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Moved to general engine forum.
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
racereese
Oct 3, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
6998poncho
Sep 25, 2015 02:56 PM
