KPA conversion?
Old May 10, 2001 | 11:09 PM
precision350's Avatar
KPA conversion?
Is there any way to convert the KPA into voltage? My scan tool only reads MAP voltage and I when I look at any of the tables concerning MAP, thay only consist of KPA.
Old May 11, 2001 | 12:56 AM
Bob Wooten's Avatar
if i am not mistaken it is 0 - 5 Vdc is 0 - 100 kpa. so 2.5 v is 50 kpa etc.
chime in here if i am all wet.
BW
Bob Wooten
71 Camaro, 91 EFI
r71chevy@earthlink.net
www.r71camaro.homestead.com
Old May 11, 2001 | 05:22 PM
92Z's Avatar
92Z
It depends on Barometric pressure (different weather, different Baro. press.) and altitude also. What I do is turn the key on (car off) and view the MAP volts and record it. Then when I make scans all of the MAP volts are relative to the MAP volts with the engine off (since this is the MAP at atmospheric pressure). Example: key on engine off MAP volts=4.95. When making scans the MAP volts at a certain RPM (lets say 2000RPM) read 2.1. If you divide 2.1 by 4.95 you get .4242 which would be 42% of 100 Kpa which is 42 Kpa. Hope this helps
[This message has been edited by 92Z (edited May 11, 2001).]
Linson
Oct 24, 2025 02:00 PM
2012sergen11
Oct 13, 2015 07:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
