a little confusion in adjusting the air fuel ratio with the tech article...
I was reading in the tech article and stated the leanest condition is 3mV and richest is 1V.
Then it stated ideal for full throttle is .850mV-.900mV. Is that not lower than the leanest condition stated above at 3mV or am I understanding this wrong?
I reliaze that this is not the most acurate way of finding the fuel ratio but I'm going with what I got for now. I know it's running rich with my new 30lb injectors.(406 tpi) And it's showing between 600-900 mV at full throttle. And if it should be between .85-.9mV I take it I'm running bad rich. I just need some one to back me up on this.
appreciate your time...
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
What tech article are you referring to?
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Tim
<font face="Verdana, Arial" size="2">Originally posted by TRAXION:
Tim
</font>
Tim
</font>
www.thirdgen.org/newdesign/tech/o2tuning.shtml
I would recommend sending an e-mail to the webmaster (Dirk Timmerman). I don't have the rights to change the articles.
Tim
Tim
<font face="Verdana, Arial" size="2">Originally posted by afgun:
You are correct; it should read 850mV - 900 mV instead of .850 and .900, respectively. Tim, can you get that corrected?</font>
I figured it out a little after I wrote it.
86IROC112
Aug 17, 2015 02:00 PM
