Why Open Loop most of the time?
Subscribe
Jun 11, 2001 | 03:55 PM
I have determined that my car stays in the open loop most of the time.
I have a stock chip.
I am using a 180 degree HIGH FLOW thermostat.
(It always stays open).
I am also running cheap Flowtech headers with a NIECHOFF Oxygen Sensor.
Why does the car stays in the open loop most of time. Is it because:
1. The oxygen sensor does not warm up properly?
2. Or because the coolant never reacher mid/high temp?
I do not have access to scanner.
Any ideas will be appreciated.
89Iroc, 305 TPI, WC T5, 3.08 Posi, Headers, Hooker Y-Pipe, 3 inch over the axle, Flowmaster 80, No Cat, Aluminium Driveshaft, Ported Plenum, Air Foil, K&N, All free mods,
Reply 0
Jun 11, 2001 | 05:58 PM
Quote:
<font face="Verdana, Arial" size="2">Originally posted by DANIELEK:
</font>
How'd you determine that?.
If your operatin temp is near 180, that more then enough for C/L enable.
Highest stock CT enable for C/L, that I know of, is 156dF.
Reply 0
Subscribe
