Knock detected? Some advice?
Old Jun 15, 2001 | 09:09 PM
leirch's Avatar
Guys, I just noticed on the way home today , with diacom hooked up, when going down the road, i put the clutch in rev the engine up, or even at idle and rev the engine up i get knock sometimes. not a WHOLE lot, but some, Any idea as to whats going on?
I have a diacom run i can send to anybody that is willing to look at it.
Thanks,
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Old Jun 16, 2001 | 12:13 AM
JPrevost's Avatar
Car: 91 Red Sled
Send that info my way, I have Diacom v2.85 but I don't think it matters what version it is.
I've been running 93 or 89 and haven't noticed any difference with my engine, either way I usually get like 15 counts on knock after a half hour of hard driving. If from what I've read, this is normal because the knock sensor isn't a perfect sensor. Grumpy, when does the ecm (746 or 747) start to retard the timing? Does the ecm look at the knock over a period of time like the TPS? I would hope it does but I'm not sure.
, Jon (350 TBI!)
91 Red My website
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
jaridjohn
Oct 5, 2015 07:01 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
