VE Tuning question
Old Jun 19, 2001 | 12:18 PM
Mojo's Avatar
VE Tuning question
I started tweaking my VE tables yesterday, and I noticed that the lower VE tables are pretty close out of the box. The BLM's are between 125 and 129, 129 being the most common. When it hits the upper VE table, the BLMS jump to 140-155. I'm adding a lot of fuel to the upper VE's. My question is this: how much is too much in tunercat? At 2400 rpm my values are in the 90's. That just tells me that when I get to the higher RPM's and the thing really starts gobbling fuel that the values will be well over 100. Seeing as to how the graph in tunercat only goes to 100, would I be better off increasing the injector constant and pulling fuel out of the lower VE table?
408cid 1985 Corvette
http://www.mojosgarage.com
Old Jun 19, 2001 | 12:26 PM
leirch's Avatar
Its entirely up to you as to how much work you want to do. From what i can tell your going to need to rework either table HEAVILY... so take your pick...
Old Jun 19, 2001 | 12:36 PM
Mojo's Avatar
I just answered my own question... The average increase was a multiplier of 1.15. When I tried to increase the entire upper VE by a multiple of 1.15, I got an error telling me that I exceeded the max value of 100. I'll try bumping the constant up by .5.
Old Jun 19, 2001 | 01:47 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Did you already bump up the cylinder volume constant?
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Old Jun 19, 2001 | 02:57 PM
Mojo's Avatar
<font face="Verdana, Arial" size="2">Originally posted by TRAXION:
Tim
</font>
Sure did!
MustangBeater20
Oct 29, 2022 09:20 PM
Vintageracer
Jan 10, 2020 05:33 PM
theurge
Aug 21, 2015 12:46 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
