1985 corvette, 870 ecm, and tuner pro rt
Old Aug 23, 2006 | 01:21 AM
vectra28's Avatar
Car: 1985 corvette
Engine: 383 Superram/RHS Heads
Axle/Gears: 3:07
Hi gang,
I have a 1985 corvette that I'm trying to get datalogs for. I have Craig Moates ALDU1, CABL1, and tuner pro rt. I have the .bin files for my vehicle as well as the 1F.xdf file. I have the ALDU1 set to the 10k resistor and the USB drivers installed from Craig's site. The com port on both my laptop and the software is set to COM3. I can't seem to get connected. I have an email into Craig about a possible problem with the CABL1 because when I do a cable test in tuner pro it says cable not connected or detected (8192 baud). If I leave just the ALDU1 connected than I get a connection established message. Does tuner pro rt not work with the 870 ecm? Other than the repinning of the harness to the 165 is their a software that will work with the 870? I have used WinALDL in the past however maybe it doesn't give as much info as tuner pro rt? Any help you can guys can offer would be greatly appreciated.
Chad
Old Aug 23, 2006 | 11:44 PM
vectra28's Avatar
Car: 1985 corvette
Axle/Gears: 3:07
I have the problem fixed.
Old Dec 23, 2006 | 11:19 PM
billdorn's Avatar
Engine: 5.0L tpi 85, 6870 ecm, 1$F
Transmission: T350
how did you fix it??? i have the same problem. (nevermind it worked today, no idea why)
Old Dec 26, 2006 | 01:07 PM
8UpAFord's Avatar
Car: 1988 Corvette
Engine: 5.7L TPI L98
Axle/Gears: D36 2:59
165 suck too, I can't ever seem to get a consistant connection it always drops out. I use Datamaster.
Hotrodboba400
Dec 10, 2019 07:07 PM
Drone358
Dec 10, 2015 08:16 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
85Special
Sep 3, 2015 04:21 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
