Where can I get 90-91 Y-body 7727 connectors??
Old Jul 1, 2001 | 12:50 PM
88SS6SPEED's Avatar
Car: 88 Monte SS
Engine: Super-rammed L-98 383
Transmission: T-56 6-Speed
Axle/Gears: 8.5" G-BODY G-80 3.73
I have a 7727 ECM and want to mke a wiring harness for it, but can't locate any connectors. Any help would be appreciated.
88 Monte SS 355 TPI/LT-4 HOT CAM/AFR Hydra-rev/ T-56 6-Speed/1-3/4" full length headers/3" X-PIPE assembly/ 8.5" G-80 rear with 3.73 gears.
http://community.webshots.com/user/ssynergy
www.y-t-g.com/88monte
Old Jul 1, 2001 | 01:54 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
There are some other GM model bodies that use the same connectors. I got some from a '89-90 Pontiac Bonn. at the P-A-P yard.
Any GM where the computer is under the hood.
(7727's that is).
Chronologically challenged. But still kicking!
'92 CAMARO RS
305 TBI 5/spd (now TPI)
B4C Alt.
'69 camaro-BB/Lenco,1050 dominators, /Pump Gas/no drugs 8.97-150+/3200lbs.
SoCal Thirdgen F-Bodies
Old Jul 1, 2001 | 02:58 PM
88SS6SPEED's Avatar
Car: 88 Monte SS
Hey Don, I will look, but I couldn't find any with the same pin out as the Vette, or connector color. Plus, the different color connectors have blank pins unlike the 7165 and 7730 connectors. I will definitely look at those year bonneville's What style vehicle did you put the 7727 ECM in, was it that in your 92 RS? RSVP, and thanks.
Old Jul 1, 2001 | 09:05 PM
Dyno Don's Avatar
88SS:
I put it in a '72 Chevy truck under the hood.
I used the color of wires from the 7730 using the two diagrams Y-F bodies from service manuals. I think I got the disgram on the Pont. too, and matched it up.
'92 CAMARO RS
B4C Alt.
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
dusterbd
Sep 29, 2015 08:40 AM
